I have a part. This part is designed in metric system, weight unit is gram.
I set custom property of part, Weight --> SW-Mass@Second_roll.SLDPRT --> 8027g.
How to set second property with for example pounds (can I add equation to properties?), without changes of units in document?
Or how to add note with weight in pounds?
Set up an equation and multiply the mass (grams) value with the conversion factor. Now add a property in the part and set the value to this equation. Finally link the note in the drawing to this property.
