Hello! I can corrugate a sheet (roll formed) or bend it (brake formed) but I can't seem to roll it then bend it. I've tried edge flange but each edge is angled differently so they do not follow the proper bend curve. I've tried sketched bend but it keeps telling me it is unable to execute the bend. I even tried lofted, but this creates multiple sheets and I only want one flat. Does anyone have any suggestions?
Thanks!
oh, now i get it.
won't the press brake bends cause the corrugation to flatten out in those bend areas?
even if you get the flex to work in there, the flat will never be accurate.
after all, getting a flat-pattern was the point of this exercise, correct?
i think you might be better off doing a regular sweep.
even with a sweep you won't be able to depict the "flattening" effect the press brake bends will have on the corrugation.
