hi
i'm fairly new to solid works so please be nice
i'm trying to model and create a mold for a small part - see the attachment
i modeled in 3ds max, but i need to create a prototype in stl, and then create a mold for it, the material will be a semi-rigid plastic, i will like it to be parametric so i can change sizes
can anyone give me a "best procedure" to create this, also how is the mold going to work if the part is a sphere like shape where can i place the parting line
please any help would be appraciated
Thank you
You are not going to be able to mould this in one piece.
But you could produce the STL in one!
You will have to mould it in two halves with a 'jagged' split along the circumference, then weld together.
