hi
It is an simple option to add\delete a column , if you are using customized column view then please change it over there ...
No, i just have one customized column, the column i want to remove is the default column of EPDM explorer.
Thanks for your help
Do Le Vu.
That column is a default column in the window's explorer. The other way round to hide this is to do this to move the ends of the column attached in the picture file.
But: This returns to the original mode once you log out and log in
You can move the columsn to any postion in the Windows Explorer, By Just holding your LMB and drag and drop to any location you like.
To move the "Modified" column in your case to the extreme right in the windows explorer so that it does not appear to visible unto somebody horizontally scrolls.
Cheers !
Raghu.
Do Le Vu.
Cheers !
Raghu.
