8 Replies Latest reply on Jul 13, 2017 6:10 AM by Tommaso Maiullaro
    EPDM task to save DXFs for all sheet-metal parts
    Anton Nanchev
      I’m trying to create an EPDM task which generates dxf files for all sheet-metal parts passing specific workflow transition. The code generates separate dxf for each part configuration. I'm using the SolidWorks Task add-in to execute the following script:
      Option Explicit
          Dim swModel                 As SldWorks.ModelDoc2
          Dim vConfNameArr            As Variant
          Dim vConfName               As Variant
          Dim bShowConfig             As Boolean
          Dim bRebuild                As Boolean
          Dim bRet                    As Boolean
          Dim swDocSpecification      As SldWorks.DocumentSpecification
          Set swDocSpecification = swApp.GetOpenDocSpec("C:\Users\ananchev.TL-HQ\Desktop\sheetMetal.SLDPRT")
          Set swModel = swApp.OpenDoc7(swDocSpecification)
          Set swModel = swApp.ActiveDoc
      'Is it a part document?
      Dim modelType As Long
      modelType = swModel.GetType
      If modelType <> SwConst.swDocPART Then
          swApp.SendMsgToUser2 "A sheet metal part must be open.", swMbWarning, swMbOk
          Exit Sub
      vConfNameArr = swModel.GetConfigurationNames
      For Each vConfName In vConfNameArr
          bShowConfig = swModel.ShowConfiguration2(vConfName)
          bRebuild = swModel.ForceRebuild3(False)
          Dim FilePath As String
          Dim PathSize As Long
          Dim PathNoExtension As String
          Dim NewFilePath As String
          FilePath = swModel.GetPathName
          PathSize = Strings.Len(FilePath)
          'PathNoExtension = Strings.Left(FilePath, PathSize - Len(swModel.GetTitle)) + "Export\"
          PathNoExtension = "C:\Users\ananchev.TL-HQ\Desktop\Tests\" + "Export\"
          NewFilePath = PathNoExtension + vConfName & ".DXF"
          'Export Flat Pattern
          bRet = swModel.ExportFlatPatternView(NewFilePath, swExportFlatPatternOption_RemoveBends)
      Next vConfName
      'Close the document
      swApp.CloseDoc (swModel.GetTitle)
      When I run it as a macro within SolidWorks everything goes fine, but executed from my EPDM task it generates the dxf only for the first part configuration and then ends with an “The object invoked has disconnected from its clients.” error.
      The debug option marks the line where the next part configuration is loaded in SWx.
      I tried a lot of different options for the code, but each and every time the same behavior and error. I’m sure I’m missing something, but I can’t find it.
