1 Reply Latest reply on Feb 17, 2011 12:32 PM by John Fitch
    Temperature Effects on Simulation Run
    Chris DiSalvatore
      Can a simulation run be done to show deflection of a material at high temperature directly in the simulation program, or does a flow simulation run need to be done first and transitioned over?
        • Re: Temperature Effects on Simulation Run
          John Fitch
          Run a thermal model in Simulation, using conduction, uniform bulk convection, radiation, generation....
          and THEN you import that temperature solution T(x,y,z,t) into a subsequent stress or other study.
          If you apply temperatures on a surface in a static stress study,   the temperatures will influence the stress/strain results, BUT ONLY on that surface.  ie thermal diffusion does not take place in that static stress study.
          John
