JPJeisson Parra10/02/2011
Hello. I'm trying to design some new tube routing and reuse some old data from previous installations. Is there a relatively simple way to do it in SW? I tried some of the routing features, but I don't think they're what I need. My main focus is to reuse the previous geometries; if I can reproduce those, most of my problem will be solved.
I'm having a hard time reading and understanding the old bend data tables I have as well as translating them into a solid model. Can anyone help me with any of this? I'm not an expert with SW, but I would consider myself a competent user.
Here is an example of the data I'm talking about:
Header 1 | Header 2 | Header 3 | Header 4 | Header 5 | Header 6 |
Saw | Burred | ||||
Length | 43 | 44 | |||
Bend Procedure | RH | ||||
Bender Type | Douglas | ||||
Bend Data | From "A" | Bend [deg] | Turn [deg] | Dial [deg] | Rad |
Bend 1 | 22 | 50 | 0 | 1.25 | |
Bend 2 | 18 | 42 | 165 | 1.25 | |
Bend 3 | 10 | 8 | 260 | 1.25 |
Thanks for any help you can provide.
