How can i turn off preview for some file, or for all files? or some files with spe. extension?
Thanks so much
Thanks so much
I don't think you have the ability to turn on the preview of the any files or all the files unless you un-install some viewer dll's.
Cheers !
Raghu.
Is there any way to disable preview for the large files, when click on it, some computer will be freeze.
Yes, can turn the preview as images, It will initially be image once you open up. If you want to rotate the model. Just click on the image and automatically it switched to edrawings.
To set this up. Click on Display > Options > Check the Show SolidWorks files as bitmap images and DWG Files as bitmap images.
This would help to perform better. And I also make it a point the I switch on the data card always in the Vault view until unless i want to see the file.
Cheers !
Raghu.
Cheers !
Raghu.
