I have two assemblies that share many components. I would like to copy parts from one and past them into the other.
Is there a way to copy several parts at one time keeping the mates that are between the copied parts?
I tried to create subassemblies of the parts to be copied, thinking I could then just drag over the subassembly but the "form subassembly here" command is not always available. Is there another way?
Tom,
What I would suggest is in the assembly that has these components,
holding down the ctrl key select them all that you want, then RC and form a sub assembly
of them. Call up that subassembly and save it as some name. Then insert that sub assembly
into your other assembly then disolve it.
