I have a large number of drawings I need to export to DWG and I was able to set it up in task manager no problem. But any of the drawings with multiple sheets saved as seperate files for each sheet. If I manually save it I can save them in one file, but Task Manager does not seem to have that option. After some search it looks like I will have to use a macro, however I am unfamiliar with using them so I am making sure that I'm not missing anything. This is something we will probably be doing often so I want to find an easy way to do it.
Thanks, Mat.
Dear Mat,
Welcome to SW forums !
Yes, if you export the Solidworks drawings to DWG format, the individual sheets are saved in the different files, It's an general practice that we have many drawings in one file in the AutoCAD.
Cheers !
Raghu.
