Hi.
if I wanted to insert a subassembly just to represent its size and shape and this subassembly is huge in file size can I convert that subassembly to a smaller file type that is a dumb solid and insert it into the assembly?
Hi.
Hi Colin,
If you are using SolidWorks 2011, You can use De-feature to represent the assembly. It makes the part as dumbsolid and yet retain the shape and size.
If older version, You might have to try and save the part into some neutral file format and import it again to solidworks. But there may be data loss.
Cheers !
Raghu.
Use Speedpak
SpeedPak creates a simplified configuration of an assembly without losing references. If you work with very large and complex assemblies, using a SpeedPak configuration can significantly improve performance while working in the assembly and its drawing.
Thank you Deepak, yes I forgot there was such thing although I have never used it, now I'm about to learn how.
Cheers
Use Speedpak
