Take a look at the attached assy called E4068117 TEST FIT. What I need to do is drag the pipe off the arbor to make sure it is loadable/unloadable. You will have to suppress the mates on the pipe first. I have been trying to use the move component command with the physical dynamics option and its so slow its unusable. Is there a better way to accomplish my goal?
Thanks for any help.
Solidworks 2011 sp1
Hmmm,
Nobody else must be using this command. It does work but its extremely slow almost to the point of useless. It must take a Hal 9000 to run this command.
