Hi all,
I have created a planar surface which I then used to create a Cut with Surface.
However, see the attached picture. The resulting cut is not planar and I have no idea why.
The picture on the left shows the surface I used for the cut and you can see the cut without the surface over on the right.
Mike without looking at the part it might not be easy to say anything. Any chance if you can put up the part too??
BTW why that surface has dotted lines??
