Help!
I have had an on going problem that i just cannot resolve. It started about 6 months ago when i was running 2010. I upgraded today to 2011 and the problem still exists.
The issue is when i launch Solidworks by either selecting from the menu or even if i run the EXE file, the program doesn't start. Once in a while it will launch in the background but you can never see it on the screen. About 50% of the time i can see the process running in Task Manager but sometimes not.
Here is the kicker, if I double click on ANY existing Solidworks file the system starts and runs fine. Works like a champ in all aspects.
Ideas?
Tom
Something to try. Start SW Rx and try the two options at the bottom - starting with options bypassed and using software OGL. Depending on what you see, there might be a clue there that would help find the problem. I would also try doing a repair on the install.
WT
