Newbie question here. I am placing a pipe on the exterier of a tank (cylinder) such that it is pointing radially outward. I can't seem to get my constraints to work. I have tried:
1. Axis of pipe perpendicular to tank wall. This was my first guess. Not sure why it doesn't work.
2. Axis of pipe perpendicular to tank axis. I guess this is satisfied, however, pipe axis is not forced to intersect tank axis so orientation is not forced.
3. Axis of pipe coincident with tank axis. Thought this might fix the above weakness but fails because it wants both axis to match along their length instead of just one point.
4. Pipe face parallel to tank wall. Not allowed (which I can understand).
The tank and the pipe are both parts that I am putting together into an assembly.
Any ideas? I could create construction geometry (sketches) but it seemed like overkill.
Marty
Just some thoughts here as I am making up a picture of what you want.
If the parts have proper center planes, then make a vertical plane of the pipe coincident to the vertical plane of the tank - that will basically constrain it side to side. Then take the end face of the pipe and make it tangent to the tank wall - this will suck it up against the side of the tank. Then establish the height based on the planes of edges or whatever.
WT
