When I run an analysis without using a bolt series, I can get the resultant loads on the bolt. When I run a simulation with a bolt series connecting three components, I cannot get the resultant forces on the bolt. I get an error that says "Pin/Bolt/Bearing forces are not available due to non-existent connectors or changes in the connector faces." The only difference between the two models is whether or not I have the box checked for advanced series. How do I get the shear values and tension values on the bolt when using the series bolt feature?
Matthew: i got it to work if I select only the shank face of the middle component (I tried three stacked plates and the "Bolt Series" option). I was able to reproduce the error message you see, when I selected all shank faces of each component. Can you let me know if that fixes it for you? -Tony
