When I use the Surface-Extend command, it causes a split line to disappear. I'm starting to sound like a broken record because during the switch from 2009-2010, the knit feature changed how it handled split lines, and now Surface-Extend apparently has changed.
The reason why I care is that now my part fails, and I have to spend about an hour fixing it. Which is fine, except when I have tens if not a hundred parts where this is going to be a problem....
I expect that when I upgrade from 2010 to 2011, that my parts SHOULD NOT all of a sudden fail. ...sigh...
Is there any way to make surface extend not delete a split line?
Sam
Sam,
Split Lines have always been a little flaky. I can duplicate this behavior back at least to 2007. I suspect it has always been this way. Perhaps if we all send an example into our VARs and complain, something will eventually get done.
Jerry Steiger
