What determines K - factor when using "Convert to Sheet Metal'?
Question asked by Dean Baragar on Jan 25, 2011
Latest reply on Jan 25, 2011 by Dean Baragar
When we use 'Convert To Sheet Metal' (or 'Mirror Part' as well, I believe) the K - Factor seems to be set to  0.5 (as a default?) and in order to change it you need to edit the Sheet-Metal Feature. Because of this it can be easily forgotten. What determines the K-Factor in this instance? And is it possible to take the information from the sheet metal gauge table like we would if we were using the Base Flange/Tab feature to make a sheet metal part to determine K-Factor, thickness and bend radius rather than entering it in manually?
