I'm in Assembly mode with the top level assembly opened.
Can someone please explain what is the difference between Insert new assembly under the Insert Component" icon vs right click on the top level assembly in the feature manager tree and select "insert new sub-assembly"? Seems both options are inserting a new empty sub assembly under my top level assembly. Is there a preference which to use?
Kris.
Both are same as you stated. You can use any one of them or the icon on the assembly toolbar or customize a key board short or the S key.. choice is yours
