Noob question. How do I change the default units to metric (mm)
thanks cwc
Hi Craig, go to Tools/Options/Document properties. Select Units and change to whatever you like.
Next time you should try searching first...
Note: If you want this to be your default to all your parts, you must save your setting in your template file.
Cheers
Filipe
Epic! Thank you so much, I did search but I did not search for document options.
Cheers
Filipe
