new plane is created at angle
Question asked by Jerry Watts on Jan 21, 2011
Latest reply on Jan 21, 2011 by Jerry Watts
I'm making a wireform using 3d sketch and need a loop at 60 degrees to the top plane.  No problem draw a centerline 90 deg. across top plane from the end of my line add another on the right plane at 120 degrees.  Click add plane and select the end points of the lines, simple right?  So why does it produce a plane at a weird cocked angle and how can I fix it.  See attached pdf.  Oh ya, this is w/SW-07  I'm sure I've run into this before but can't remember how I fixed it, DOH!
Jerry
