Hi all,
I am trying to copy a 3d curve i created using the Curve through reference points command. I basically have 50 features that are all slightly different but will be based on the same 3d Curve and since once you use the curve for one feature, it is owned by that feature, then i would need to create 50 curves! There must be a way to just duplicate the curve 50 times? It takes a long time to create each curve.
Thanks for your help!
Rami
The Curve feature exists in the FM
Open a 3D sketch, select the Curve and use Convert Entities to create geometry in the 3D sketch
That 3D sketch can then be referenced/shared in other features
