Where can I find and print a copy of the standard shortcut key list?
TIA
Maurice
TIA
Maurice
The problem with just printing the list as you see it is because some hotkeys are document specific. This means that you have to do it 3 times - part, assy, drawing - and then pull out the duplicates. Therefore the list that I maintain - I do the work one time so everyone else does not have to. :-)
WT
Go to http://www.kcswug.com/main/index.php?option=com_docman&task=cat_view&gid=40&Itemid=60 and grab the hotkeys file. It shows all the standard out of the box settings for each SW version and also what I do to our machines.
WT
