I currently have a custom property field for all parts called "Number" which my users fill out for part numbers. When we create a bill of materials that includes our parts and hardware coming out of the Toolbox, the column that I've created for "Part Number" using "Number" as the property fills out correctly for parts we have created and obviously not for the Toolbox hardware. Is there anyway to have the Toolbox files fill in a custom property field titled "Number" with the "Part Number" information that we enter into the Toolbox Settings program?
Automatically no.
But what you can do is when you bring the toolbox part in RC on it in the feature
manager and select "Edit Toolbox Definition" and type in your own configuration name
and set the custom prioperty in that config. Then the next time you brin g in the part
it should be the way you want it.
Over time the toolbox will populate with the custom properties you need and want.
But I caution you. Make sure you back up your tool box files in a different location.
