Make part from block
Question asked by Kris Persaud on Jan 15, 2011
Latest reply on Jan 15, 2011 by Deepak Gupta
I've created a two blocks within the same sketch. On one of the block I've created a path around its parameter and save the block as path. I saved the other block also. I need to make separate parts out of these blocks. Do I need to create an assembly layout to do this? I tried to do this by creating a layout and then insert the blocks but when I do this the blocks doos not follow the path I've created on the block named path. Does this mean that when I save a block that contains a part and insert it in an assembly the block looses path?
