Does anyone know if there is a way to import a bearing as an assembly and not as a part? The bearings from toolbox open as part files. I also tried downloading a bearing from skf and seams to be a part file too.
You mean making each ball, the cage and everything,no? I was searching for an easier and faster way to make a bearing but it seams there isn't. Thank you!
Why you need them as assembly. If you looking for a realistic motion, then you need to model them as separate parts and mate them in assembly. If you're bearing are multi body part, you can convert them directly to assembly.
I need a realistic motion as you said. I downloaded a rod end and by watching the part file I made a ball and the rest of the rod end I saved it as a different part file. Then I made an assembly and it worked. But in bigger and more complex bearings it would be difficult and it would take a lot of time building it, no? The bearings of the toolbox aren't multibody parts. Is there a way to make a bearing, let's say one of these of the toolbox as multibody part file? And when having a multidody part how can I transform it into assembly?
Check this Assembly from Part – No mates required
But please note that they will be fixed in the assembly. So you need to set them to float (right on the part in assembly and select float to make them free). Now add the mates as required.
But again why you need a realistic movement? Why can't you use a bearing as part? The idea is this will make the assembly file heavier and complex?
Eva,
No, they are what they are being parts. You can import one and transform it into an assembly.
