I made a fully defined sketch using a spline, needed three of the fully defined sketches in my part so I went to make a linear pattern of it.
Each "copy" ended up looking like fancy pinstripe on a lowrider car......not anything like the original.
Then I tryed copy and paste.....even worse results......
I had to finally use arc's to create the shape I needed...Why can't I use splines, fully defined, and copy or pattern them without it looking nothing like the original?
If you change it to a proportional spline, does it then pattern/copy correctly?
