This error occurs when I try to check a file into the vault & keep it checked out. The file can be checked in & then checked back out. EPDM has been un-installed, the registry cleaned of EPDM & re-installed & the problem persists.
Has anyone had this error & what was your solution.
System is:
Dell T3500 quad core
XP x64
SolidWorks 2009 x64
EPDM 2010 x64
thanks
If you are using SP3 or 4, this may be a known bug. Ask your VAR and reference: S-051125 in the KB.
