Static load analysis attempted on beam structure 4 X 4 in tube 0.25 in thick. Run as assembly with coarse mesh and received 63 components
that failed to mesh. Tried incompatable mesh option and ran finer mesh but still received a number of components that failed to mesh. Saved
assembly as part and ran mid sized mesh, and received message 'thickness not defined for 1 or more shells'. Any suggestions on successfully
running this analysis would be appreciated. Thank you.
Hi Chris:
Could you share your model to let us have a look.
