Is it possible to rename a file on initial check in based on a variable value in the file data card? I know it could be done with a template but these files are being created outside the vault and then copied into it. Plus there are many file types which would each require a separate template.
Mike
EPDM 2010 SP2
API could do this. Maybe Dispatch too?
Make sure you have them set to do the rename AFTER the file is initially checked in else you may lose some references.
