I'm trying to create a miter flange on the top four surfaces of this part but it is only allowing me to create one flange and does not create the 45 degrees miter. Can someone please see what I'm doing wrong?
Kris.
Kris.
Hi Tony,
I was able to model the flange on the top with the corners mitered. Also I was able to flatten the sheet metal part as you can see in the attachment but I'm confused why you said that a sheet metal shop cannot manufacture the part with the miter flange on top. Did I mis read your comment?
Kris.
Skip the Edge Flanges. Apply an L shaped Mitre Flange directly to the Base Flange.
