I think this is a basic question but I searched and couldn’t quite find the answer I’m looking for. I have a sub assembly that consists of 2 timing pulleyss on either end of a shaft. I have added configurations to the shaft for 3 different lengths. The sub assembly that contains this shaft pulley part also has the driving servo, belts etc. I need to be able to insert the servo/shaft pulley assembly into the master assembly and select which shaft length I want for that particular instance. If I change configurations all the sub-assemblies change not just the one I want to change. Can I do this from the top level assembly? How do I do this?
Peter-
Are the sub-assemblies all separate instances that you've added in and not patterns of the original?
If they are you should be able to have 3 of the same sub-assembly and have them all each on 3 different configurations in the master assembly.
Your part will have 3 configs eg. Small, Medium, Large.
Your Sub-Assembly will also have to have 3 configs, Small, Medium, Large.
In your Master Assembly pick what config for each instance you want.
Message was edited by: Paul Mihala
