1 Reply Latest reply on Jan 5, 2011 11:32 AM by Joy Garon
    Dispatch and Copy/Shared
    Barry Stump
      I am not seeing this in the help or in the forum.  Is there a method using Dispatch to do a Copy/Shared for a file or files from one location in the vault to another.  I do not want duplicate files, nor do I want to simply move the files, but I want to share the files between two locations.   Asside from writing a full addin I suspect using the Dispatch Shell command there would be a way to put the code in.
        • Re: Dispatch and Copy/Shared
          Joy Garon
          Hi Barry,
          You cannot share a file via dispatch. (Nor can you move it - you can only Copy or Delete).
          Regards,
          Joy
          p.s. This can be done programatically via the API
          EdmCmd_PreShare and EdmCmd_PostShare
          A file is shared from one folder to another one.
          Members
          Type
          Description
          mlObjectID1
          long
          ID of file to share.
          mlObjectID2
          long
          ID of folder to share file from.
          mlObjectID3
          long
          ID of folder to share file to.
          mbsStrData1
          BSTR
          Source file path.
