value of parameter/name of parameter
Question asked by mitchell shellenberger on Jan 4, 2011
Latest reply on Jan 4, 2011 by Scott McFadden
On a print is there a way to see the name of the parameter, not just the value.  I have a title block that is driven by some parameter in the part file.  However once the value of the parameter is pulled into this title block, I can't tell if it is a driven parameter, or a something some typed in.
In Pro-E there is a button that allows you to flip back and forth from the value of the parameter and the name of the parameter.  This makes is easy to see what is beeing driving from parameters, and what is not.  For example in the title block in the description field I can see that the descrition is "wiggit" and then if I hit this button, I can see that what I was seeing as "wiggit" is the value of a parameter called "description" is the wiggit part file.
Is there a way to do this in SW?
