I have a stand alone part (not used in assembly) that is used in two different projects that different people have access to so I would like to have a copy of the part in both folders. Is this possible?
Daniel
Workgroup does not allow two parts with the same name to be save in two different projects. I suggest you allow both users read only access to both projects so they can use the common component.
