I seem to be experiencing a bug where I can only view my assembly when I select the right, left, top, etc views. If I try to rotate it at all from these, everything disappears instantly. Is there a fix for this?
Elliot, you need to upload the parts also along with assembly.
In your particular case, one of you part has been mated away from other parts/origin and that's why you see this OR some of the plane(s) may be situated away from main assembly or is huge in size. Simply click each part in the feature manager and try to locate them in the graphic area.Then position them accordingly.
Also read this post for your future reference.Forum Posting
