Smart Component not working as intended
Question asked by Kris Persaud on Jan 2, 2011
Latest reply on Jan 3, 2011 by Mike Agan
I'm working on Lessen 2 of Assembly Modelling 2010 and I can't get this to work. The Cap is supposed to update per the configuration table and adjusted to the different diameters of the pipes. Can someone please take a look at this and let me know what I'm doing wrong? Let me know if I need to supply more information. The idea here is the cap has 5 configurations (max and min diameters) and when assembled to the various pipes in the Test assembly the ID of the cap is supposed to adjust to fit the pipe it is assembled to. I assembled the cap to the Smart Base assembly and make the Cap a "Smart compontent" in context of the assembly. Then I created the Configuration table to fit the various diameter of the pipes. Per the exercise, when I mate the cap to the pipes in the Test assembly the cap ID should adjust to the Pipe OD. Also The config table is supposed to pop up for me to select the config to use but the table is not popping up. At least that is what the exercise implied.
Kris.
