Toolbox Fasteners mating at an angle!?!
Question asked by David Stone on Dec 31, 2010
Latest reply on Jan 5, 2011 by Jerry Steiger
Hi
Recently started having an issue with dropping toolbox fasteners into an assembly.  For example, I select a hole edge, choose a washer and select to insert into assembly, which locates fine (concentric and coincident).  I then repeat the process for a bolt or screw using the internal washer circular edge.  This used to position the bolt/screw as expected but now it's dropping in at 90 degrees to the normal (and expected) axial location
Is anyone else experiencing this and know how to fix it?  This onlt seems to have started happening since installing SP5 on SW2010.
