I upgraded to 2011 and I can't seem to locate the pdmwadmin function. Has it been integrated in some way? Or did I miss a critical option in during the install process? I tried to insert the SW2011 disk to add it like I have done with previous SW versions, but I got no where.
Any help?
There was a spot during installation that you needed to check in order to install it with 2011.
Not to fear, you can still add it back in easily.
Go to the Control Panel to Add / Remove Programs
Select the SolidWorks 2011 installation and select Modify (might also be called Change)
You will want to modify the installation of SW and when you are given the option to change what is installed in SW, make sure that you select PDM Admin
Finish the install as normal
Chris
