Hi All,
I have created assembly with parts created with top down methodology with one driving sketch and created configurations in it.
When I then use this assembly into my main assembly with two instances then I cannot switch between the configurations and cannot see the effect of dimensional changes in the sub assembly. Please see the attched SolidWorks Assembly for reference.
Regards,
Amit
First off, Merry Christmas! The kids are not up yet so I get to play. :-)
Your model seems to function on my machine. I switch between the Default, 600, 400 configs and after a couple Ctrl-Q's everything seems to update. Try that and see if things work for you. When I first opened the assy, I switched configs and things were out of place. But it could also be that I don't understand your problem.
WT
