I'm trying to create a curve with the 'Equation Driven Curve' command.
The function as the image attached is possible in this command using some of the functions ?
For example the 'sqr (a) square root returns the square root of a' is as the image attached ?
I believe that your issue is that all you need to do is use a the following for a square root "^.5". I have set t=1 and c=2 in the equations. Please see attached image and model. I hope this helps.
Rob Stupplebeen
