Hi Everybody
I have problem with big bend angle.
As you see from attached file - it 20 degree angle, and SW don't want to unbend it...
Material- 16GA Stainless Steel (0.063") , as per my tables- for this material bend deduction- 0.1
When I put it- SW mark bend like mistake..
Wrote to SW support - receive answer :
"The only solution is to change the inputs for calculating the bend.
In this case it would be changing input for Bend allowance by either inputting a different value for Bend Deduction or using a different option such as K-Factor.
Increasing the Bend radius would also allow the bend to work. Adjusting material thickness may be a different option. "
Tried to switch from BD to k-factor (0.44) - not working
Tried to chage radius from 0.03 to 0.0625 (that tools which I have in metal shop)- same result.
Idea to adjust material thikness becouse SW can't calculate it is even not funny.
Please, let m eknow if somebody have REAL solution for this problen. I think, I'm not oly one , who need bend differnt , than 90 degree...
I need to receive real flat pattern, if I put numbers from the air SW will eliminate mistake, but flat pattern will be wrong...
Mark
The file Mark has uploaded has a k-factor of .46 for the entire part, not the .100 BD he talks about.
The 30 degree bend does not work with a .100 BD. Which is not a big surprise as I do beleive .100 BD is not a good number for that particular bend. I would adjust just that bend to a proper BD for a 30 degree bend.
Mark needs to do some empirical testing to come up with the correct BD for the 30 degree angle. Then create a SW Gauge Table for his material instead of hand typing in a number from his paper charts.
http://help.solidworks.com/2011/english/SolidWorks/sldworks/AllContent/SolidWorks/Core/Sheet_Metal/comb_Sheet_Metal_Gauge_Bend_Table.htm
The link from the SW Help shows that you need to add BD, BA for more then just the cardinal angles. SW can then more accurately interpolate the tweener angles.
http://www.screencast.com/t/ogQ29VWsL
The video shows that you can edit individual bend features for k-factor, BD, BA, etc, to override the global k-factor, BD, BA, etc set in the SheetMetal2 feature at the top of the feature manager.
Cheers,
Anna
