Can anyone help with applying a corner weld into a sheet metal part, i see it listed in the help menu but it is not very clear as to how it can be applied?
Hi Micheal, thanks for the help, I managed to get 3 corners welded but am having problems with th 4th one.
Hi Paul,
I can only think it has something to do with the way SW has Convert to sheet metal has produced a slight difference in the rip gaps
The Convert to sheet metal can seem to be a great starting point if you are not sure about SM but it is prone to produce small differance's in what should be identical corners.
I have found SM models where you have modelled the part totally in SM are a lot more robust, its not as easy but safer in the end.
Michael
PS I just cut your model in half & mirrored over the good half
Hi Paul,
It should just be a case of selecting the edge face of one of your flanges, change the rad to suit & let SW fill it in.
Can you post one of your parts?
Michael
PS Welcome to the forumn
