My analysis type is external. It is a thermal simulation for a LED lamp.
The simulation is completed successfully, no warnings and errors.
After simulation, there is no problem to view the cut plots and surface plots.
But flow trajectories cannot be inserted and the button on the menu bar is gray.
Can anybody tell me what is the problem?
BTW, my configuration is Windows XP 64bit + Solidworks + Flow simulation (2010 SP4).
I think I know : the last cut plot you displayed was certainly "solid temperature" or "heat transfer coefficient", to sum up something that cannot be used with flow trajectories.
Try the following : view settings, then change to "temperature" or "velocity"
Now you menu should not be greyed out any more.
Loïc
