I'm having a Dell T7500
SolidWorks give me a message that I'm running under low resources when I'm using only 13Gb of ram and the CPU is running under 10%. I'm also using Snagit to capture image and edit them. Could it be related or what else could it be.
Patrick Molimard.
Patrick,
I am using snag-it too and I am not running into this issue.
How often do you restart your machine?
Is your virtual memory set high enough?
When was the last time you did a disk clean or a defrag?
