Hiya,
Has anyone had problems getting the Schedule Render to work (PV360 2011)? The setup window looks as it should, but when you click ok nothing happens.
Tom
Hiya,
Tom
mmmm.... no. I've just had another look at the help menu information for schedule renders, and it does mention task scheduler but without really clarifying the process. Do I need to combine the two functions and activate one with the other? This seems strange. Surely I should be able to stack up lots of renders directly within PV360?
Yes, the help isn't real helpful in this case.
You can schedule as many renders as you like in PV360. That's no problem. When you schedule the renders in PV360 what your really doing is setting up tasks in SW task scheduler. In order for SW task scheduler to complete the tasks it must be open.
So, schedule the renders in PV360 and then when you have that complete open SW task scheduler. You don't have to do anything in Task Scheduler, just be sure it's open.
