hi everyone,
I would like to draw a Split Line from one end to other end. But it does not work. It appeared Rebuild Erros that the projected sketch does not split the selected faces. it may not intersect the faces or be totally coincident with an edge on the face.Please see attached file.
The end of the line does not extend past the edge of the face. I have attached a revised model, where the split line works. Note that you cannot see it, because it does not create two seperate faces, but it is there. I do not know your design intent, but just make the line extend past the edges of the face and it will work.
