Hi all,
It's been a while since I last joined in the forum. Been very busy lately. Anyways, I have a problem. Actually its on my officemate's PC. Everytime she sketch a circle or an arc it becomes ellipse. Only the image is changed but it can be dimensioned as circle or arc. Has anyone experienced the same? How did you correct it? By the way, it happened when she changed a desktop bakcground image. But cannot revert when she changed to original background.
Message was edited by: Lope Timajo
Check the resolution in the display settings (under Windows Control Panel). Not all of the settings have the same width-to-height ratio, which will cause circles to look distorted. Pick one with a different ratio and see if that helps.
