I am trying to creat multiple configurations in an assembly that has three driven dimentions (change one the other two update). I have my default configuration set to 30". when I create the second configuration and set the necessary dimention at the required 42" everything will update accordingly, however, when I click on my configs. to toggel between them they will not update according to the set dimentions for each config. am I doing something wrong or is there a bug yet?
1. A driven dimension can't be changed, driving dimensions can.
2. How are you changing the dimension for the configurations? Double click and change the value in the model, Design Table, RMB Configure Dimension?
Easiest way for me is to RMB and select Configure Dimension. To get this option do not be editing a sketch, Double Click on the feature you wish to change and then RMB on the dimension and select Configure Dimension. This will pull up a table where you can change values and add configs. Here is the help on it: http://help.solidworks.com/2010/English/SolidWorks/sldworks/AllContent/SolidWorks/Core/Configuration/c_ModifyCfg_Modify_Configurations.htm?id=2dc0274b0bd24ef0a5f6253d927a94da#Pg0
here is help on the double click dimension option: http://help.solidworks.com/2010/English/solidworks/sldworks/legacyhelp/sldworks/configuration/dimensions_in_design_tables.htm
