Have recently started using non-linear simulation - i have set the new material properties for young's modulus e.t.c,
I set a time curve before starting the simulation but am struggling to find the permanent displacement results/ displacement when the load is removed???
Any help?
James.
Hi James: When you plot displacement (for example) it is supposed to have an option in the PM to choose the step at which you desire displacement. There should be a spin-box adjacent to it, that you can increase until it gets to the last step in the analysis. Then choose "OK" and it should show the displacement field all over the model (in color) at the last step, which presumably is the point at which the applied loads are zero. Does that work on your system?
